1988 Mazda b2200
OLD SCHOOL 9
Engine Performance problem
1988 Mazda b2200 4 cyl Two Wheel Drive Manual
The engine runs fine, but as I push in on the clutch to shift it backfires between every gear unless I keep the rpms very low between shifts. I ask the mechanic to check the timing and he said it checked out ok, Now what ?
Sep 20, 2008 at 2:16 PM
  • 75,988 POSTS
Check the accelerator pump might not be squirting fuel when needed during acceleration to prevent hesitation. Could be spark plug with wrong heat range
Sep 20, 2008 at 2:22 PM
