1987 Mazda b2200 Seems to be overheating
1987 MAZDA B2200
55,000 MILES • 4 CYL • 4WD • MANUAL
SAMELLJOANNE
It appears that my truck is overheating by my temp gauge. I replaced the thermostat and it does not always give me problems. I am thinking it might be the water pump? I dont seem to be leaking, but I do have to replace the antifreeze sometimes.
I have not seen any signs of the head gasket being the issue. No water in the oil or radiator, engine still runs great. If it is the water pump how difficult to replace? What else could it be?
May 12, 2009 at 11:57 AM
JRAY1989
  • 8 POSTS
[quote:43bb26d911="samelljoanne"]Engine Cooling problem
1987 Mazda b2200 4 cyl Four Wheel Drive Manual 55,000 miles
I have not seen any signs of the head gasket being the issue. No water in the oil or radiator, engine still runs great. If it is the water pump how difficult to replace? What else could it be?[/quote:43bb26d911]
hi there, their not that bad just its a job. I have the same ride 1987 2wd b2200 I highly suggest fixing it mine warped the head going down the road the gauge had gone out of it and it stuck at out 1/4 the way. the milled it down im trying to fix it now good luck
May 12, 2009 at 3:04 PM
