1986 Mazda b2200 Mazda b2200
1986 MAZDA B2200
12,000 MILES • 4 CYL • 2WD • MANUAL
BULLDOG102DS
  • 5 POSTS
I bought a mazda b2200 a few months ago and started it up, it will run but not very good, it blows blue smoke and does not have very high RPM's, i have replace the water pump, head gasket, put new plugs in and still the same problem, a rough idle at low rpm's. when it does run, when i took the EGR valve off it was packed with black sook so i cleaned it out and it made no difference. i dont know what is wrong with it. i like the site.
Oct 23, 2008 at 1:29 PM
Hi bulldog102ds and welcome to 2carpros
it blows blue smoke: it means its burning oil in the cylinders
The combustion chamber is leaking could be valves or rings-cylinder wear if this is happening it will not run right-it has to be repaired to produce the correct engine compression
Oct 23, 2008 at 7:52 PM
BULLDOG102DS
  • 5 POSTS
so why was my EGR valve filled with that black soot?
Oct 24, 2008 at 1:42 AM
