1982 Mazda b2200 Coolant overflows as soon as engine is war
137,000 MILES • 4 CYL • 2WD • MANUAL
MCCARTHY_FRAN55
My coolant overflows from the radiator to the reservoir as soon as my engine gets to temp, causing overheating. I had the radiator drained and flushed 2 months ago, replaced the cap and thermostat, and it appears as if the thermostat is working as the upper hose is full and hot while the engine is running. Is it likely my radiator is clogged? Are there any other explanations as to why my radiator would dump coolant into the reservoir as soon as it gets to operating temperature? Thanks, Frankie
Apr 17, 2010 at 12:58 PM
  • 75,988 POSTS
If the radiator is not clogged-test the water pump if its circulatiing coolant thruout the engine
Apr 21, 2010 at 11:14 AM
