1989 Mazda 929 Wipers Stopped
SMILE025
I have 2 questions. 1 for my more recent car a [u:dbf753ef88]1989 Mazda 929[/u:dbf753ef88], around 300000k for both(if that makes sense) it has been snowing and pouring rain here for the past few weeks and when I went to turn my car on I heard a thud noise when I turned the windshield wipers on and they didn't come up, they stopped working... Do you know why? Do I need a new motor? My dad checked the fuse and said it wasn't that.
2nd questions: My old car is a 1987 Toyota Cressida. I stopped using it because there was white smoke coming out of the tail pipe and it was using all the antifreeze and the waterpump was never full(which we replaced it) then the heater would start blowing cold air, and the temperature gage kept going up would that be the head gasket that is broken? and could I repair it with just a new thermastat (dont know spelling)? please help thanks, you can also email me asap at awesomelindsay@hotmail.com
Nov 26, 2006 at 4:45 PM
  • 55,849 POSTS
For your first question check the control arms from the motor to to wiper arm, it sound like the pivoit bushing has gone bad. Your second question sound like your head gasket is bad. :?
Nov 27, 2006 at 3:15 AM
Suggested Repair
On the 1989 Mazda 929, inspect the wiper linkage and pivot bushing between the motor and wiper arms before replacing the motor; the fuse was already checked. On the 1987 Toyota Cressida, the coolant loss, white exhaust smoke, cold heater, and rising temperature indicate a failed head gasket, not a thermostat-only repair.
Conversation Summary
The owner asked about a 1989 Mazda 929 whose wipers made a thud and stopped working in wet weather, and about a 1987 Toyota Cressida that used coolant, smoked white from the tailpipe, blew cold heat, and overheated after a water-pump replacement. The expert said to check the wiper control arms and pivot bushing, and said the Cressida symptoms sound like a bad head gasket rather than a thermostat fix.
