1988 Mazda 929 Oil Consumption
I have a 1988 Mazda 929 with a 3.0L Fl V6 engine. It's an automatic and has 222,996 original miles. I just bought the car (which had a new engine put in) early this year. I put 10W-30 Synthetic Blend it in and it takes 4.5 quarts to fill. It's been about a 1.5 months since I changed the oil. I just recently checked it and it was .5 quarts low. I do an average amount of driving, not too much or not too little. When I first bought the car it was running very strange as it would shake terribly when accelerating and got terrible gas mileage. I bought the car 300 miles from me and brought it back here under these conditions. After trying to replace the spark plugs a few weeks after the purchase, I noticed that one of the spark plug wires wasn't plugged in and that it was running on 5 cylinders the entire time. I wasn't sure how long the previous owner had ran it like this, but I thought that was very idiotic. After plugging it in, the car began to run much better. Could these have caused the oil leak? And could it have caused any other problems?
Apr 22, 2007 at 3:20 PM
Give it a major tune-up and for the oil leak the plug will not do that.
.5 quart loss if there's no actual leak then its thru cylinders wear/tear its a sign of engine rebuilding at the age.
A quart less than 500miles is a bad sign of an engine worned-out. Sorry
Apr 22, 2007 at 11:33 PM
Suggested Repair
Perform a major tune-up. A disconnected spark plug wire would not cause an oil leak. If there is no external leak, the half-quart loss is consistent with cylinder wear at this mileage; monitor consumption, since losing a quart in under 500 miles indicates a worn engine that may need rebuilding.
Conversation Summary
The owner of a high-mileage 1988 Mazda 929 reported losing about half a quart of oil over roughly 1.5 months and asked whether previously running on five cylinders because of an unplugged spark plug wire could cause an oil leak or other damage. The expert said the plug wire would not cause the oil loss, recommended a major tune-up, and attributed oil use without an external leak to cylinder wear that can signal the need for an engine rebuild.
