1993 Mazda 929 My 4w ABS light is on and my car is making a
1993 MAZDA 929
18,400 MILES • 6 CYL • 4WD • AUTOMATIC
JGRIFFIN
I was driving my car at a normal speed and everything was fine. I stopped, turned off car, and got back in. Once I started to drive my 4W ABS light came on. So I pulled over, turned off the car and popped the hood. The light went off, but there was a hissing noise. I turned back on the car and the light came right back on and the hissing noise never stopped. Its been 2 hours and the noise is still there and when I turn the car on and put it in Drive the light comes back on. HELP!!! Please...
Apr 15, 2008 at 9:59 AM
2CARPRO JACK
  • 11,533 POSTS
Need to poke your head around and find th ehiss. Might be the vacuum assist for the brakes.Look for a fairly big hose leaving the booster (behind master cyl) and going to engine
Apr 15, 2008 at 10:20 AM
JGRIFFIN
Well now my car won't start. The hissing noise continued thoughout the night. I took the battery out and took it to auto zone to be recharged. they rechared the battery and I put it back in my car. It still won't start. Now what should I do?
Apr 16, 2008 at 6:47 AM
2CARPRO JACK
  • 11,533 POSTS
The engine doesnt turn over, or it turns over and wont start?
Apr 16, 2008 at 7:20 AM
2CARPRO JACK
  • 11,533 POSTS
If it turns an wont start, look at the hose I mentioned before, if it is cracked or broken it could create a large enough vacuum leak to keep it from starting
Apr 17, 2008 at 2:21 AM
