1993 Mazda 929
1993 MAZDA 929
BIGJKC
Engine Mechanical problem
1993 Mazda 929 6 cyl Two Wheel Drive Automatic
rolling over but not giving any fire
May 29, 2010 at 8:33 AM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
May 29, 2010 at 10:59 AM
