1992 Mazda 929 replace waterpump
ELGOOOFY
1992 Mazda 929 6 cyl Two Wheel Drive Automatic
how do I replace the water pump and timing belt?
Apr 30, 2008 at 11:54 AM
BMRFIXIT
  • 19,053 POSTS
1. Disconnect negative battery cable 2. drain engine coolant 3. remove coolant fan and shroud 4. remove drive belts 5. remove idler pulley for Ac and P/S if equipped 6. remove crankshaft pulley 7. remove coolant hoses and by -pass hose 8. remove distributor 9. remove timing belt cover 10. turn crankshaft to align pulley 11. remove timing belt remove water pump
https://images.2carpros.com/forum/automotive_pictures/99387_929_1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_929_1.jpg
Apr 30, 2008 at 12:34 PM
ELGOOOFY
do I need to buy a timing belt tensioner? what other special tools do I need, Please send more info
Apr 30, 2008 at 6:35 PM
BMRFIXIT
  • 19,053 POSTS
Check automatic tensioner rod projection
rod should project .47 -.55 " (12-14MM) from tensioner body
if not within specification replace tensioner
May 1, 2008 at 1:08 PM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_chry_v6_2_25_3.jpg
May 1, 2008 at 1:11 PM
ELGOOOFY
it will be my first time replacing a water pump and timing belt. I'm going for it on Sunday,
May 2, 2008 at 4:20 AM
MICHAELC3179
You do not have to remove the crank pulley or timing belt to change a water pump on a 1992 mazda 929. the water pump is not driven by the timing belt. I have already done this!
Sep 28, 2012 at 6:01 PM
