1991 Mazda 929 PASSING SMOG TEST
PAUL HOLLAND
Engine Performance problem
1991 Mazda 929 4 cyl Front Wheel Drive 174144 miles
FAILED TWICE TEST EMISSIONS TOO HIGH, HC&NOX AT 15 MPH. I'VE ALREADY REMOVED THE EGR VALVE AND CLEANED THE PORT OUT WHAT ELSE SHOULD I DO?
Feb 10, 2010 at 7:44 PM
  • 75,988 POSTS
HC failures mean unburned gasoline is passing through the engine and entering the exhaust. The three most common causes include ignition misfire, lean misfire and low compression (typically a burned exhaust valve). Ignition misfire can be caused by worn or fouled spark plugs, bad plug wires or a weak coil. Lean misfire results where there is too much air and not enough fuel, so check for vacuum leaks, dirty injectors or a fuel delivery problem. In addition to these, hydrocarbon failures can also be caused by oil burning due to worn valve guides, valve guide seals and/or rings.
Feb 10, 2010 at 9:40 PM
