1989 Mazda 929 Head Gasket Replacement
1989 MAZDA 929
66,000 MILES • 6 CYL • 2WD • AUTOMATIC
RMMAGOW
Long diatribe so there's a donation:-)
A timing belt idler pulley bolt sheared off and made a pretty total mess out of the engine. The bolt that sheared was in the right (passenger) side head. So thinking I could easy-out the broken piece and helicoil fix the hole I went at it. Screwed up royally and drilled into the water jacket. Fast forward. I've removed both heads, a non-trivial exerciise, there's not a damn thing wrong valve-wise. When the belt breaks on this (SOHC) all valves slam shut. I've purchased a replacement head for the damaged side. I've also purchased a valve grind gasket set and new head bolts. I own the factory shop manual too.
My concern center around installing the heads. It is getting cold, low 40's to mid 50's. Will I encounter improper installation with everything cold? The head install calls for oiling the bolts and head facing, torque the bolts in order to 14 lbs. Then, in order, turn 90 degrees, then another 90 degrees. The old head on the left looks good, measured flat enough, the engine deck seems OK. Is there anything I should be extra careful about? Will the colder weather affect the install? Should I do anything with the head gaskets, spray with oil or just be sure all is clean and dry before assembly? This is the most important part of the job and I do not want to screw it up. Advice and hints greatly appreciated. Any other advice with re-assembling this motor is highly desired too. Thanks Much
Oct 4, 2008 at 4:29 AM
MERLIN2021
  • 17,250 POSTS
Do not apply anything to the heads or gaskets! These are pre treated with thier own sealant, most important is torquing them correctly, No the temperature is ok for the job! Dont forget to use RTV at the end of the valley before you reinstall the intake manifold.
Oct 4, 2008 at 7:11 AM
RMMAGOW
Hi, I don't understand the RTV in the valley deal for the intake manifold. I'm putting new intake manifold gaskets on too. Is there somewhere else I should be using a little extra sealant? Prior to this catastrophe I never had trouble with the engine, never over-heated or anything. Still waiting for all the other parts to arrive. Biggest car job I've done in 25 years or more. Good car and actually pretty straight forward to work on, but still, you really have to take off a lot for this job. Thanks for the reply.
Oct 4, 2008 at 8:04 AM
MERLIN2021
  • 17,250 POSTS
In the instructions for the intake manifold gasket, they usually give you a diagram of where to apply the sealants...it is at the front and bach, or in front drives, left and right ends of the block.
Oct 4, 2008 at 11:05 PM
