It was smoking really bad, loud noise when trying to crank, now does not crank
2,000 MILES • AUTOMATIC
KJONES95
My car was smoking real bad and was making a loud noise when you crank it. Now it will not crank. I was told my battery was dead, but I am trying to see why it is smoking. When I used to drive it it will drive slow then pick up speed all of a sudden.
Sep 9, 2018 at 5:43 AM
  • 31,937 POSTS
What color smoke do you see? Is the engine using coolant? Have you replaced or charged the battery and tried to do a re start?
Sep 10, 2018 at 10:08 AM
KJONES95
White and yes, my battery is brand new but the car just been sitting. I just put an starter on it.
Sep 10, 2018 at 11:32 AM
  • 110,248 POSTS
If the smoke was white, it sounds like you may have a bad head gasket. White smoke usually indicates that engine coolant is getting into the combustion chamber. Here is a test to determine if there is an issue with the head gasket:
Follow that link and let us know what you find.
Sep 15, 2018 at 12:05 PM
