1996 Mazda 626 Won't Shift Out of 2nd
PRNCSSNASTETSON
1996 Mazda 626, automatic transmission, with 166771 miles. I had a new motor put in 9 months ago. The Stupid mechanic didn't replace the front seal on the transmission so I had that replaced about 2 months ago. It was running fine for awhile but for the last week when it gets to the normal operating temp. it doesn't want to shift out of second gear. My check engine light is on and when I start it up and drive after I have driven about 5 miles my over drive off lights starts to flash. Any ideas on what is causing this?? I'm lost. I have tried manually shifting it and that doesn't help either.
May 1, 2007 at 4:49 AM
  • 75,988 POSTS
[quote:b46c2464fd="prncssnastetson"]1996 Mazda 626, automatic transmission, with 166771 miles. I had a new motor put in 9 months ago. The Stupid mechanic didn't replace the front seal on the transmission so I had that replaced about 2 months ago. It was running fine for awhile but for the last week when it gets to the normal operating temp. it doesn't want to shift out of second gear. My check engine light is on and when I start it up and drive after I have driven about 5 miles my over drive off lights starts to flash. Any ideas on what is causing this?? I'm lost. I have tried manually shifting it and that doesn't help either.[/quote:b46c2464fd]
Have the coolant temperature and throttle position sensor-and could be shifting solenoids.
May 1, 2007 at 7:58 AM
Suggested Repair
Check the coolant temperature sensor and throttle position sensor. Shifting solenoids may also be causing the no-shift condition.
Conversation Summary
A 1996 Mazda 626 automatic with 166,771 miles had an engine replaced nine months earlier and a transmission front seal replaced about two months later. After running fine, it now stays in second gear once at normal operating temperature. The check engine light is on, and the overdrive-off light flashes after about five miles. Manual shifting does not help. The expert advised checking the coolant temperature and throttle position sensors and noted that shifting solenoids could also be the cause.
