1998 Mazda 626 No Drive or Slow Movement
WHGINCA
hi there
I have mazda 626 1998 LX 4 cylinders automatic,4 doors sedan with little over 118,000 miles on it.I recently was driving when car lost power an was moving slowely.I was trying to accelerate the speed pressing the gas pedale,but the engine was making lot of noise and car was still moving slowely.When I stopped I was trying to start moving again,but I couldn't.I tried changing geers from P to D or R but car didnt move.I turned it off and start the engine again.After I switched geers from P to D,I was able to drive for about a block and car was moving slowely about 20 mph.I tried to speed up and same problems occured.After parking on the side of the road,I was trying to change from D to P and back to D,but the car wasn't moving.I checked The fluids and they were in good condition,cause they were changed few months ago.
I was told I might need to change a whole transmission and estimate is about over 1000,00 dollars.
I would appreciate if you could tell me what could be wrong and if there is anything else that might be a problem?>>>
Thank you
Aug 29, 2007 at 5:13 AM
  • 31,937 POSTS
Hi there,
Modern auto transmissions are very complex devices, if as you say you have no drive, or minimal at best it sounds terminal. Best thing to do at this stage is to remove the transmission oil pan and check for excess metal in the pan, if so bad sign sorry, is the oil bright coloured or a dull brown and smells off? if so more bad news. As far as fixing there beasts, there is no short cuts, you re build the entire transmission or fit a chang over unit, Second hand at your peril as you have no idea as to that it's like untill you drive it. best let a transmission specialist guide you and don't be afraid to get a second opinion, after all it's your money.
Mark (mhpautos)
Aug 29, 2007 at 3:57 PM
Suggested Repair
Drop the transmission pan and inspect for excess metal and dull brown or burnt-smelling fluid. If either is present, the automatic transmission is likely failed and needs a full rebuild or a quality replacement unit. Have a transmission specialist confirm the diagnosis and get a second opinion before buying a used unit.
Conversation Summary
The owner of a 1998 Mazda 626 LX with about 118,000 miles reported sudden loss of power, loud noise under acceleration, and little or no movement in Drive or Reverse despite recently changed fluids. An expert said the automatic transmission is likely failed, advised checking the pan for metal and the fluid color and smell, and recommended a full rebuild or replacement through a transmission specialist rather than a risky used unit.
