Mazda 626 stuck in neutral
NGUYEN.MD87
Transmission problem
Mazda 626 4 cyl Two Wheel Drive Automatic 8900 miles
My mazada 626 is stuck in neutral, I can move the shifter but it does not shift into any other gears. please help!!
Aug 5, 2010 at 10:48 PM
  • 31,937 POSTS
Check that the transmission is actually selecting gears, if so this will be an internal problem, probably a pump or torque converter problem, this will have to be towed to a trans specialist for detailed investigations as to the actual cause of the failure.
mark (mhpautos)
Aug 6, 2010 at 2:35 AM
