mazda 626 LX,96,2.0,118700 mileage
DWIGHT ROLLINS
car started over heating due to a shortage in the radiator fan plug which I found out later. But before I discovered this was the problem it over heated one day and the overflow water hose blew off and hot coolant and steam came shooting out . After this incident the car would take very long to start but after it warms up it starts on one crank,the air conditioning stop working and during driving conditions it accelerates very slow and the radiator fan now stays on from the moment I get the car started. I got a low voltage coolant sensor switch reading from the trouble codes and changed the switch,spark plug wires and rotor pin but all the current problems still exsists. What else needs to be done ?
Nov 25, 2007 at 9:30 PM
  • 75,988 POSTS
Is it still overheating? if so have the tests done below to rule out a combustion leakage
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Nov 25, 2007 at 9:37 PM
DWIGHT ROLLINS
It does not over heat anymore the problem was the radiator fan plug which was fixed. But all the other problems I've listed, takes long to start, poor acceleration and the ac stopped working also the radiator fan stays on while the car is running, these problems still exist.
Nov 25, 2007 at 9:55 PM
  • 75,988 POSTS
Check the fuel pressure with a gauge
Nov 25, 2007 at 9:56 PM
DWIGHT ROLLINS
Thanks I will check and make that donation.
Nov 25, 2007 at 10:02 PM
