mazda 626
1962 MAZDA 626
ERIC626
I have a 02 Mazda 626... have found that when the engine is engaged and I am running the air, heat, or just the fan that a sqeaking sound begins...Turning the fan off causes the sqeak to stop...Do I need new belts or compressor or what...?[/b]
Apr 28, 2006 at 3:09 PM
COSMO
  • 347 POSTS
check your alternator belt tension...if its loose....tighten it, if its cracked at all....replace it. If you replace it, repalce the powersteering belt too.
Cosmo...Mazda Tech
Apr 28, 2006 at 3:29 PM
