Loud squeal at low RPMs
KGOULD67
I have a 1999 Mazda 626 4 cyl. with 116k on it. There was a squealing noise at low RPMs (start up and at stop lights). The Alternator belt came off. I have replaced both belts with the correct ones. I have adjusted the belts to have little deflection. The squealling has yet to stop. I have re-adjusted to ensure I was not too tight or too loose. It doesn't matter either way. Could this be a symptom of my power steering pump going bad. Are there bearings in the power steering pump? I really don't want to replace parts here and there that don't need to be replaced. Please help me in this embarassing situation. Thanks in advance.
Nov 26, 2007 at 8:02 AM
  • 31,937 POSTS
Hi there,
Quick check, remove both belts, start engine, noise? YES=Internal NO= external Fit inner belt start engine noise YES= your found it, NO, fit next belt, isolate the noise this way and then you can start to check the suspect component.
Mark (mhpautos)
Nov 26, 2007 at 8:54 PM
