Now the code P0404 comes up ( P0404: Exhaust Gas Recirculation Circuit Range/Performance). My mechanic is baffled. What could this be NOW?
1997 Mazda 626 EGR P0404 Shudder
What part would you change/adjust to get the EGR back in range? Is there an EGR Circuit that could be changed/fixed? I guess I could also have a tune-up.
BTW, for readers' reference: I found the Trouble Codes conversion
https://www.2carpros.com/trouble_codes/obd2
Check whether the computer is activating the solenoid to apply vacuum to EGR
P.S. One mechanic suggested a possible role by the ozygen sensor. Is this possible, even though that's not the code coming up?
If the computer don't get the right signal from the O2 sensor, its gonna react differently.
Suggested Repair
Inspect the full EGR system: remove the valve and check it and its passages for carbon, verify the VSV solenoid and vacuum supply to the EGR, and confirm the computer commands the solenoid to apply vacuum. Also consider whether the oxygen sensor is reporting mixture correctly when EGR opens, and try the recommended premium fuel if pinging is a factor.
Conversation Summary
A 1997 Mazda 626 with a 6-cylinder engine and manual transmission developed an EGR code, then a flow code, and now P0404 after the EGR, MAP sensor, and solenoids were replaced with dealer parts. It still shudders around 2500 rpm. The expert said the EGR may be opening too soon and advised inspecting the valve and passages for carbon, checking the VSV solenoid and vacuum, and confirming computer control of the solenoid. The expert also explained that a faulty oxygen-sensor signal can affect how the computer responds when EGR dilutes the mixture.
