2001 Mazda 626 Code P1652
CSWANSON69
2001 Mazda 626, 4 cyl, 63K miles. The software that came with my code reader says that this code means "idle air control monitor disabled by PSPS". I have located the idle air control (a small part that attaches to the intake manifold). It is very expensive but rather simple to replace. I don't know, though, if this part is the same as the "monitor", or if the monitor is something connected to the wire that comes out of the idle air control. I don't want to replace a $400 part and find that it's not the problem. Also, what is "PSPS"?
Thanks
Sep 18, 2007 at 3:21 AM
FISHERMAN
  • 937 POSTS
[quote:564e38ee90="cswanson69"]2001 Mazda 626, 4 cyl, 63K miles. The software that came with my code reader says that this code means "idle air control monitor disabled by PSPS". I have located the idle air control (a small part that attaches to the intake manifold). It is very expensive but rather simple to replace. I don't know, though, if this part is the same as the "monitor", or if the monitor is something connected to the wire that comes out of the idle air control. I don't want to replace a $400 part and find that it's not the problem. Also, what is "PSPS"?
Thanks[/quote:564e38ee90]
PSPS Means: Power steering pressure switch...
Pressure switch is located right on the side of the pump.
Check that first!
Probably its just stuck!
Sep 21, 2007 at 2:29 AM
FISHERMAN
  • 937 POSTS
Also .. Idle air control monitor Its disabled by PSPS
Which means that the problem could be the PSP Switch..
Check that first and let us Know!
Good luck!
Sep 21, 2007 at 2:33 AM
Suggested Repair
Before replacing the idle air control valve, check the power steering pressure switch on the side of the power steering pump. It may be stuck and is what disables the idle air control monitor.
Conversation Summary
The owner of a 2001 Mazda 626 has a check engine light with code P1652, described as the idle air control monitor disabled by PSPS, and is unsure whether the expensive idle air control valve is the failed part. The expert explains that PSPS is the power steering pressure switch on the side of the pump and recommends checking that switch first because it may be stuck.
