Car will not start
PRESTER
My 1993 Mazada 626 4 cylinder with 133000 miles used to cut off but will start when the ignition key is turned. However, recently when it stalled it never started. There is no power, no fire no nothing. What seems to be the problem and how can I rectify this problem?
Jun 26, 2007 at 11:27 PM
DANCARLSON
  • 50 POSTS
If you have no power at all, check the battery and the cables. I had an old Ford Ranger that the cable that ran from the battery to the starter was broken inside the casing and the truck would not start, no power no nothing.
Thanks
Dan
Jul 2, 2007 at 11:35 PM
ROBCHOP
[quote:7c26d7a6de="prester"]My 1993 Mazada 626 4 cylinder with 133000 miles used to cut off but will start when the ignition key is turned. However, recently when it stalled it never started. There is no power, no fire no nothing. What seems to be the problem and how can I rectify this problem?[/quote:7c26d7a6de]
i have the same problem, The engine turns over, but won't start. it happens every once in a while(specially when I'm in a hurry) The computer codes check normal. I was told that the master selenoid relay or the starter are going out (within the starter). if this is true what is the master selenoid relay and where is it located? if this is not the problem, what is? Please, help!!
Nov 26, 2007 at 10:36 AM
