Mazda 626 AC Hot at Idle
KELBY71
My a/c works fine as long as the car is moving but when I slow down or stop it instantly feels like heat. People sald it is normal for the air to not be as cool but I don't think it should feel like the heat is blasting.
Aug 1, 2007 at 2:54 PM
GREASE MONKEY
  • 23 POSTS
Yes the air will not be as cool as when you are going down the road but it should not feel like heat.
Have you had you the A/C checked lately? It could be low on freon. All A/C systems will leak a little freon out over the year's and need topped off every few years.
Let me know. I hope I have helped
Aug 12, 2007 at 2:57 AM
Suggested Repair
Have the A/C system checked for low refrigerant and topped off if needed. Some cooling loss at idle is normal, but hot air is not.
Conversation Summary
The owner reports the Mazda 626 A/C cools while the car is moving but feels like heat when slowing or stopped. The expert says reduced cooling at idle can be normal, but hot air is not, and recommends checking the system because refrigerant can leak slowly and may need topping off every few years.
