1998 Mazda 626 AC causes odd symptoms
1998 MAZDA 626
132,000 MILES • 4 CYL • FWD • AUTOMATIC
PLSMOOTHY
I own a '98 Mazda 626 with 130,000 miles. I'm hoping someone out there can shed some light on this situation. Its important to note that the following symptoms occur only when the AC is on and the car is in stop and go traffic. The car runs fine when the AC is not engaged or when the AC is on under highway conditions 1. car loses approximately 5-7 hundred rpm when the AC cycles on. Is this high? 2. I live in Southern California. The summers are hot. After driving the car in stop and go traffic I'll come to a stop (at a light for instance) and the idle speed will drastically fluctuate between the normal idle speed of approximately 7-8 hundred rpm to almost 0. In other words the car will almost stall. If I turn off the AC compressor the fluctuating stops. 3. When it gets to that point, the AC will stop cooling and the car will almost overheat. Again, these symptoms occur only when the AC is on and the car is in stop and go traffic. Any help is greatly appreciated.
May 9, 2008 at 7:46 PM
  • 31,937 POSTS
Hi there,
your engine should have an A/C idle up system fitted, this increase the engine idle speed when the A/C is turned on, i would have this inspected first, As for the overheating, make sure that the cooling fans are coming on your thermostat is working and the radiator is cleaned and flow tested. Start here.
Mark (mhpautos)
May 10, 2008 at 1:47 AM
PLSMOOTHY
Do you think I should consider installing a new AC compressor? Why does my AC cause my engine to lose so much power? The rpm's drop approximately 7-8 hundred when the AC is engaged.
May 11, 2008 at 12:43 PM
  • 31,937 POSTS
Hi there,
If the A/C compressor is running tight due to a bearing problem the load will cause the idle to drop. i would be getting the comp inspected.
mark (mhpautos)
May 11, 2008 at 5:25 PM
