1999 Mazda 626 ABS Traction Lights On
RASHIMA
hi i need to know what to do because i have a 99 mazda 626, 6 cyclinder 2.5 and my abs and traction light stays on i had a diagnostic done says its the right rear wheel speed sensor thats doing what do you recommend to do befor3e this mechanic get me for doing a whole lot of stuff that not needed and money i dont have to put out he did the first diagnostics found out that then want to charge me again to see why the sensor went bad i just want it fixed because it worry me!
Jul 8, 2007 at 10:46 AM
2CARPRO JACK
  • 11,533 POSTS
Sometimes the sensors just go bad for no real reason.Unless it has some kind of wiring damage or the ABS controller is having a problem seeing that wheel, I would just install a sensor first and see what happens
Jul 9, 2007 at 1:02 AM
Suggested Repair
Replace the right rear wheel speed sensor first and recheck the lights, unless wiring damage or an ABS controller problem is found.
Conversation Summary
The owner of a 1999 Mazda 626 says the ABS and traction lights stay on. A diagnostic identified the right rear wheel speed sensor, but the shop wanted another paid diagnosis of why it failed. The expert advises installing a new sensor first unless wiring damage or an ABS controller issue is evident.
