Thanks for your help M_J
Checked bulb and sockets and all looks good. In fact, car had a fender bender on left side 2-3- months ago and both headlight and flasher usint assemblies are new. Coincidence that the problem occurs on that side (All worked fine for 2-3- months) ! Here is more info:
- When left blinker or 4-way flashers are used, the low intensity filament flashes (front left) instead of the high intensity
- When lights are turned on along with flasher, brake lamps and dashboard lights flash. A LOUD clicking noise can be heard from the fuses/relays under the hood
Any ideas? Thanks for your help !
Wednesday, November 7th, 2007 AT 8:31 AM
