94 Mazda 626 LX - squealing when put into drive and reverse
1994 MAZDA 626
SWP
My 94 Mazda 626 (139,000 mi) had it's water pump changed a few months ago. About a month later I started getting a low squealing noise when the car is put into the Drive gear or Rear gear. Now If you drive the car the noise gets very loud and subsides for a few minutes and comes back when you come to a complete idling stop. The water pump is fine, so what else could be causing this problem. I would like to get some ideas before I run it back to my mechanic.
Thanks.
Jan 26, 2006 at 4:10 AM
10FOTUCK
  • 28 POSTS
Maybe your clutch is out on your A/C unit?
Jan 29, 2006 at 2:49 PM
SWP
The A/C is currently not working, because it needs an air compressor. I'll check this out to see if that's the cause.
Thanks.
Jan 29, 2006 at 11:57 PM
10FOTUCK
  • 28 POSTS
It doesnt have to work but if that belt is turning that pully that unit might froze up causing your squeel.
Jan 30, 2006 at 9:01 AM
SWP
Thanks for clarifying that. I would have taken it to the mechanic and they probably would have taken the A/C apart if I mentioned that it didn't work, instead of getting to the bottom of my real problem.
I'll let you know what the verdict is.
Thanks again.
Feb 1, 2006 at 10:52 AM
