2002 Mazda 626 Knocking
141,000 MILES • 6 CYL • 2WD • AUTOMATIC
REBEL5566
I have aknock in my engine that sounds similar to having a playing card in the spokes of your bicycle. The knock goes away once the engine gets up to speed. It does hesitate at lower speeds.
May 23, 2010 at 11:24 PM
  • 31,937 POSTS
So this is like a low engine speed tick?
mark (mhpautos)
May 23, 2010 at 11:38 PM
REBEL5566
Yes when it is idleing.
May 24, 2010 at 12:50 AM
  • 31,937 POSTS
Hi there, have they valve clearance checked as one may have excessive clearance, caution must be taken if any adjustment is to be made as special tooling is required to replace adjustment shims, also check foe an exhaust leak around the manifold, start here.
mark (mhpautos)
May 24, 2010 at 9:38 AM
REBEL5566
Hey Mark,
Is this an expensive undertaking? Would this also cause the car to sputter at low speeds?
May 24, 2010 at 11:06 PM
  • 31,937 POSTS
Hi there, with what you have added i would be looking at a short in a plug lead or a faulty coil, as excessive valve clearance normally won't cause the miss fire.
mark
May 24, 2010 at 11:41 PM
REBEL5566
The knock comes from the lower part of the engine. Would that have any impact as well?
May 25, 2010 at 12:38 AM
  • 31,937 POSTS
A knock from the lower part of the engine would indicate a possible bearing or oil pressure problem problem, i would be getting the oil pressure tested cold idle, hot idle and hot 1500RPM, post the findings here.
mark (mhpautos)
May 25, 2010 at 10:42 AM
