2002 Mazda 626 Car faultering
87,540 MILES • 6 CYL • FWD • AUTOMATIC
TIMONE62
Even after the fuel filter was replaced, my car still faulters or stumbles while I'm driving. Do I need to blow out the fuel lines or what do you suggest I do now.
Aug 29, 2010 at 7:40 PM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Aug 29, 2010 at 8:23 PM
