2001 Mazda 626 STABILIZING BARS
DAVE POPE
Suspension problem
2001 Mazda 626 4 cyl Two Wheel Drive Automatic
How to repair/replace the stabilizing bars front and back?
Jan 26, 2009 at 4:18 AM
DOCFIXIT
  • 18,828 POSTS
Unless you have been hit by a Mack truch bars are rather indistructable but the bushings and links do go bad and can easily be replaced. Or are you reffering to the struts? That's a bit harder
Jan 26, 2009 at 6:14 AM
DAVE POPE
my bad ..it is actually the links that make a noise, only when driving on rough surfaces.
Jan 26, 2009 at 6:36 AM
DOCFIXIT
  • 18,828 POSTS
Easy fix relpace no tension on bar unless in turn. Also replace bushings that connect to body.
Jan 26, 2009 at 6:45 AM
DAVE POPE
thanks for the advice, but I may be able to replace the links, since I did change the ones on my old dodge Caravan, not sure about the bushings you mentioned on my 2001 Mazda. I once owned an old 626 25 years ago but never had to change any sway bar links on it.
cheers.
Jan 26, 2009 at 6:53 AM
