2001 Mazda 626 shifter cable
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
BENNYGOAT
i recently had transmission problem, where i went to put it in drive and it stayed in reverse. took it to a mechanic and he said it was the shifter cable. no problem, i order the part he goes ahead and attempts to fix it. however after 3 hours he says he cannot fix it as the heater/ac unit is in the way of where the cable goes.
does this sound right? is it simple to get around this?
he sent me to some one else to fix it.
Jul 15, 2008 at 7:13 AM
DOCFIXIT
  • 18,828 POSTS
Why not adjust the old one ? was it broken? frayed?
Jul 15, 2008 at 7:27 AM
BENNYGOAT
the mechanic said he had repaired it temporarily but that i would eventually need it replacing. he said it was the grommet on the end of the cable that was broken. not sure if you are familiar with them
Jul 15, 2008 at 8:48 AM
