2001 Mazda 626 Car stalling problems
105,000 MILES • 4 CYL • 2WD • AUTOMATIC
USC0912
about 3 weeks ago I started having problems with my car stalling out. At first, it would only stall when I first started it up and put it in reverse getting out of parking spots then I could start it back up and go forward and it would run fine. It got worse over time and eventually would stall every time I started it up and put it in reverse. And now it is very hard to start the car and then it just stalls out pretty much immediately and then after it stalls a few times in a row it wont start up again. I let it sit in the parking lot for 3 days then was able to start it up and drive it to the repair shop. They then replaced the battery and the spark plugs and wires as well as the PCV valve. When I got it back it drove fine back to my place and then I drove it to class and it was working fine. When I got out of class about an hour and a half later it stalled almost immediately after I started it and repeatedly kept stalling and eventually would not start once again and I had to get it towed back to the repair shop. What could be causing these problems? Im not sure the repair guys really know what it is.
Feb 8, 2010 at 11:19 AM
  • 75,988 POSTS
Do below to determine whether it's a fuel or spark problem:
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Feb 8, 2010 at 1:18 PM
