2001 Mazda 626 car dies with a.c. on
2001 MAZDA 626
111,000 MILES • 6 CYL • FWD • AUTOMATIC
BAILEYBARBBLAINE
When I have my air cond. on and come to a complete stop or have the car in park, it will die or almost die. If the air cond. is off, it runs just fine.
Jul 12, 2008 at 1:59 PM
KHLOW2008
  • 41,814 POSTS
Hi baileybarbblaine,
The Ac compensating circuit is not functioning properly.
I would suggest giving the throttle body and the IAC valves a good cleanup with carb cleaner.
Is the Check Engine light showing?
Jul 14, 2008 at 7:05 AM
BAILEYBARBBLAINE
No, the check engine light is not on. What is a carb cleaner and how is that done?
Jul 14, 2008 at 1:00 PM
KHLOW2008
  • 41,814 POSTS
Carb cleaner is a type of aerosol cleaner used for cleaning carburettors and throttle bodies.
You need to remove the air intake hose and spray into the throttle body but if you are not into DIY, then get someone to clean the throttle body for you.
Jul 15, 2008 at 1:57 AM
