2001 Mazda 626
78,000 MILES • 6 CYL • FWD • AUTOMATIC
PROTAS
i recently started hearing a noise from the passenger side of the car when braking it may be going on when driving not sure, but definitely when braking almost like a clunking sound what would this be, also no abs brakes
Jun 19, 2008 at 7:59 PM
MMPRINCE4000
  • 8,548 POSTS
Jack the car up and put some stands under it, grab the wheel and try to move it vertically and horizontally, looking for an movement. Movement would indicate possible ball joint, tie rod, control arm bushing or bearing problem.
Remove the wheels and inspect the brakes (pads, rotors and calipers) for loose bolts or excessive wear.
Inspect the inner and outer CV boots for leaking lubricant which would indicate a torn/punctured boot. If boot is leaking, the axle would need to be replaced or a re-boot kit installed.
Inspect the motor mounts for excessive movement.
Let us know if you find anything.
Jun 19, 2008 at 11:35 PM
