2000 Mazda 626 starter
2000 MAZDA 626
90,000 MILES • 6 CYL • FWD • AUTOMATIC
BIG922
how do you remove and replace the starter
May 12, 2009 at 2:13 AM
KHLOW2008
  • 41,814 POSTS
Hi big922,
Thank you for the donation.
Here are the starter removal instructions.
Removal & Installation (626 - 2.5L A/T)
1. Release fuel pressure from fuel system. Drain coolant. Disconnect negative battery cable. Remove intake air duct and air cleaner housing. If necessary, disconnect accelerator cable from throttle body and remove throttle body.
2. Disconnect A/T cooler line. Disconnect fuel line with filter attached and position aside. Disconnect shift cable from transaxle. Remove shift cable bracket. Remove starter bracket. Disconnect wiring from starter. Remove starter mounting bolts and starter.
3. To install, reverse removal procedure. Tighten starter mounting bolts to specification.
May 12, 2009 at 2:58 AM
