2000 Mazda 626 How can I repair P153 and P155 related probl
2000 MAZDA 626
89,830 MILES • 6 CYL • 2WD • AUTOMATIC
MARKZ66
My "check engine" light is on, the code says it:
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
How can I take care of this problem?
Thanks.
Mark
mark_z66@yahoo.com
Jun 15, 2008 at 4:50 PM
A code P0153 may mean that one or more of the following has happened:
The oxygen sensor is faulty
The wiring to the sensor is broken / frayed
There is an exhaust leak
P0155 B2S1 heater oxygen circuit-check as above
Jun 15, 2008 at 5:28 PM
MARKZ66
So, what should I do?
1. Replace the oxygen sensor.
2. Replace the wire to the sensor...
BTW, the light turned on after I have an auto-accident which required the replacement of the car hood.
Thank.
Mark
Jun 15, 2008 at 6:03 PM
Inspect the wires to it-if okay either you replace the sensors or bring it in to the professionals so they can determine if its the sensor/wire or computer problem-
Jun 15, 2008 at 6:09 PM
MARKZ66
Thanks. Is bank 2 sensor one mean rear Oxygen Sensor?
Jun 15, 2008 at 6:58 PM
Its the front O2 sensor on a 2.5liter not that familar with yours but my sources says its at center rear of engine compartment-
Jun 15, 2008 at 7:18 PM
