Electrical problem
2000 Mazda 626 4 cyl
Where is the fuel relay. On the fuze cover (under hood on driver's side) it simply says "circuit relay" which is in the same location as what is on the 626 6cyl. (the 6cyl specifically calls it a fuel relay) Is this in fact the fuel relay? This is the identical relay P/N as the EFI Main Relay. If this is the correct one, then I switched it with the Main Relay and it does click, so I assume it is good however when I put it back into the circuit relay position, shown on the fuze cover it makes no sound when the ignition is turned on. Could this be because the fuel pump is messed up and doesn't complete the circuit or am I in the wrong location altogether?
Mar 4, 2010 at 7:18 AM
