2000 Mazda 626 engine will not start.
79,344 MILES • 4 CYL • FWD • AUTOMATIC
OMEGA57
Engine was attempting to start as long as the accelerator was not pressed. Now it is not even making an attempt to start as if it is not getting fuel.
Apr 28, 2010 at 6:13 AM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Apr 28, 2010 at 6:46 AM
