2000 Mazda 626 Bag Ignition Switch?
2000 MAZDA 626
DELAPENAFRED
Electrical problem
2000 Mazda 626 4 cyl Front Wheel Drive Automatic 125k miles
Turning the key on the "on" position will already start the engine. There was a smoke coming out from steering wheel. I tried to remove the cover and found out that the smoke was actually from the ignition switch. And also noticed that a while the engine was already running, there was a strange noise which seemed that the starter is still running.
Is this a symptom of a bad switch or something else.
Your help will be highly appreciated.
May 17, 2010 at 11:34 PM
  • 31,937 POSTS
Hi there,
Get a new switch fitted before you burn out the electrics as a loom fire is a real possibility.
Mark (mhpautos)
May 17, 2010 at 11:49 PM
