Transmission slips; OBD CODE indicates p1744; tcc solenoid. Will replacing the tcc solenoid alone fix the problem or trans needs complete rebuild? Trans fluid has been changing every 15,000-20,000 miles. How can I tell if the tcc solenoid is REALLY bad. What VOLTS/RESISTANCE should a bad solenoid gives? How can I change the tcc solenoid myself?
SPONSORED LINKS
Saturday, September 4th, 2010 AT 6:33 PM
