Followng are what you shoyuld be checking when it could not start.
"Â Check fuel pump volume and pressure.
"Â Check fuel pump relay.
"Â Check condition of spark plugs.
"Â Check by-pass air control valve.
"Â Ensure crankshaft position sensor has correct resistance value.
"Â Check for cracks and poor connections at mass airflow sensor or throttle body.
"Â Check ignition coil resistance.
Saturday, May 8th, 2010 AT 8:26 AM
