1999 Mazda 626 Grinding
1999 MAZDA 626
117,000 MILES • 6 CYL • FWD • AUTOMATIC
MT01945
Starting in park or neutral , grinding sound like bendix drive still engaged. Sound goes away when in reverse or drive. Shifting back into neutral or park grind noise worse
Mar 15, 2008 at 8:04 AM
2CARPRO JACK
  • 11,533 POSTS
Might be an accessory doing that. Remove the belt and see if it still does it, but dont run it long without a belt.See if you can locate where the noise is, front or rear of engine
Mar 16, 2008 at 1:45 AM
