1999 Mazda 626 Engine Cooling
10,000 MILES • 6 CYL • 2WD • MANUAL
SIERRA1250
Engine overheats and coolant/water mixture boils and dumps into the resvoir tank. The A/C is currently not working. Thats when this overheating problem began. I suspect the cooling fans are not working. I was able to check them by applying 12 volts to each fan. both worked. I have swapped out the enigne relay with the horn relay which is the same and horn worked fine. I have not seen or heard either fan work. I change the thermostat and the ECT sensor, same results. I am confused as to which fan is for what. any advise youcan share?
Feb 24, 2008 at 2:55 AM
  • 75,988 POSTS
The cooling fan will be the one facing the radiator and the other is facing the AC condenser that looks like a small radiator
Feb 24, 2008 at 2:55 PM
