Engine Performance problem
1999 Mazda 626 4 cyl Two Wheel Drive Automatic
The code for the check engine light is P0303 #3 cylinder misfire. I have replaced the spark plugs, plug wires, and the ignition coil, does not have a distributor cap or rotor. At first the car runs better then after 10 to 20 miles the check engine light flashes, the idle becomes rough, and the light comes on again. What else could it be?
Mar 7, 2010 at 12:44 AM
