1999 Mazda 626 Charge light problem
49,000 MILES • 4 CYL • 2WD • MANUAL
ALPINAMAN
We have a 1999 Mazda 626 1.8 16v.
Our problem is that the battery/charging light will come on intermittantly.t may stay on for a while,then just extinguish..
It comes on with the other ignition lights as normal and goes off when started,but then can come on anytime,there is no pattern to it..
When the light is illuminated,the battery still charges fine(have had this checked,14.1v)..
Anyone have any idea's?? Is there a charge relay that could be causing the problem??
Any help appreciated
Feb 29, 2008 at 2:42 AM
  • 75,988 POSTS
Get the alternator/battery load tested-regulator could be failing /also check the wiring harness/belt tension-
Feb 29, 2008 at 3:08 AM
ALPINAMAN
Thanks for the quick reply....
If the voltage regulator in the alternator was failing,wouldnt the charge voltage drop too when the light was illuminated ??
Thanks again
Feb 29, 2008 at 3:10 AM
  • 75,988 POSTS
The voltage will drop if the regulator is malfunctioning-Load test the battery it might not be taking the charge-
Feb 29, 2008 at 3:48 AM
ALPINAMAN
Thanks for the reply..
As said,the voltage does not drop when the light is on,it stays at 14.1v at idle.This reading was taken from the rear of the alternator.The battery is new too,so i know that is ok..
The car shows no sign of battery depleation..It always starts and has never broken down,just the charge light intermittantly illuminates???
Feb 29, 2008 at 4:17 AM
  • 75,988 POSTS
When the charge light comes On the regulator is not controlling the field windings Or the alternator itself- Do a regulator bypass test this will tell you something between the regulator and alternator. Check the fuse and also wire to wire from and to the alternator. See charging wiring schematic-EWD
https://images.2carpros.com/forum/automotive_pictures/12900_626_alty_1.jpg
Feb 29, 2008 at 8:28 AM
ALPINAMAN
Thats fantastic...
Is there anyway that the EWD can be exploded a little???
I cannot see the enough detail on there that i need.
Again thanks for the help
Gareth
Feb 29, 2008 at 4:34 PM
