1999 Mazda 626
172,000 MILES • 6 CYL • FWD • AUTOMATIC
AUTORAY
shaking idle on D drive when brake on front of red light. no engine check light on. no code found.engine speed niddle move up and down around 620 rpm.
Nov 22, 2008 at 5:31 PM
  • 31,937 POSTS
Hi there, did you do a scan? check for engine vacuum leaks, check usually tune items, plugs, leads, air & fuel filter, test fuel system pressure and do a rail pressure test to check for a leaking injector, start here.
mark (mhpautos)
Nov 22, 2008 at 5:34 PM
