1998 Mazda 626 where is the transmission filter located
1998 MAZDA 626
150,000 MILES • 4 CYL • FWD • AUTOMATIC
JGEORGIEV
I was told that replaceing the transmission filter required dissasembly on the trany what needs to be done to replace filter
Dec 16, 2008 at 7:48 AM
ZACKMAN
  • 4,202 POSTS
No need to disassemble the tranny, just the transmission pan. Drain ATF fluid. You should have a drain plug for it. Work from rear of transmission pan, loosen all trans pan bolts. Once the fluid trickles slow, remove the pan bolts, working from rear as it is easier for the fluid to drain. Remove the pan and you will see the filter. There should be a couple of screws to take out to remove the filter from the transmission.
Dec 16, 2008 at 12:21 PM
