1998 Mazda 626 Rough Shifting
162,500 MILES • 4 CYL • 2WD • AUTOMATIC
CHEERMOM069
My car has recently started shifting rough between 1st and 2nd gear. I have noticed that the engine seems to rev a litte higher and then go into gear. All other gear transitions are good and smooth. I checked the trans fluid and it is pretty dark, could this be the issue or is my trans going out?
Oct 21, 2008 at 6:43 AM
DOCFIXIT
  • 18,828 POSTS
Dark is not good if fluid has never been changed do so. The dark fluid can indicate clutch wear and slipping.
Oct 21, 2008 at 8:11 AM
