1998 Mazda 626 No running lights
253,994 MILES • 6 CYL • FWD • AUTOMATIC
RALPH T
Hi, I start the car up and have no lights. High beam only. Have all other lighting on that fuse line.
Nov 9, 2008 at 6:34 AM
ZACKMAN
  • 4,202 POSTS
You have one fuse for your side markers, tail lights and dash light, and another fuse for your low beams.
Does the dash light work?
Nov 10, 2008 at 4:02 PM
RALPH T
Yes the dash lights work
Nov 11, 2008 at 2:40 AM
ZACKMAN
  • 4,202 POSTS
Your low and high beams are off the same bulb. It has dual filaments inside the bulb. I have seen that both low beams burned out.
I would remove the bulbs, one at a time, and test them. Your bulb has 3 prongs. Use jumpers wires, connect two prongs to the battery. If the bulb is good, you will have light in two of the three combination (Prong 1 prong 2, prong 1 prong 3, prong 2 prong 3). If you only have 1 combination, replace the bulb.
Nov 11, 2008 at 10:35 AM
RALPH T
I tried changing the bulbs and they still didn't work. Thanks for all the help Ireally appreciate it.
Nov 12, 2008 at 2:27 AM
ZACKMAN
  • 4,202 POSTS
I just looked at the wiring diagram. There is a relay under the hood that controls the headlights. Try swapping the relay with something else. I mean another relay that controls your rear defroster, or something.
If swapping relay doesn't work, I have to say that your switch is bad.
Nov 12, 2008 at 12:12 PM
