1998 Mazda 626 I don't know if my problem is EGR valvle or
115,750 MILES • 6 CYL • 4WD • AUTOMATIC
SANJANA00
My car would crank but not start. I took it to two repair centres and they checked it. 1 said the oil leak caused the crank shaft sensor to go bad and that is causing the problem. the other said the oil leak is a problem and the EGR valve and air mass meter boot are giving error codes. I got the oil leak fixed. Car started, got it back but now after a week the same thing happens, cranks but will not start
What should I do? Replacing the EGR valve is expensive..Crank shaft sensor does not give an error code.
I'm a student and do not have a job. I need help !
Oct 2, 2009 at 5:24 PM
  • 75,988 POSTS
No start do below:
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Oct 3, 2009 at 3:21 AM
