1998 Mazda 626 fuel pump
17,000 MILES • 6 CYL • FWD • AUTOMATIC
UNCLESPICE
replace fuel pump
Mar 15, 2008 at 4:57 PM
  • 75,988 POSTS
If it can start, fire it up and find the fuel pump relay in the underhood relay panel and remove it let the engine run till it stalls-Now the fuel system is dispressurized-do below
Look for an access door thru the backseat-if none you need to drop the tank.
BTW why are you replacing it?
Mar 15, 2008 at 5:39 PM
